      02-09-2020, 11:25 AM   #1
FuriouslyFast
Drives: Miss Daisy
Angry Laptop to TV via HDMI...no sound
Done this a million times to watch movies. Hook laptopto home theater receiver via HDMI cable. Now, all of a sudden, I get no sound no matter what I do, but video is fine. Tried all the normal fixes, but nothing helps.
Yes, HDMI device shows up & is set as default.
Any ideas?
      02-09-2020, 11:33 AM   #2
Salty Dog
Salty Dog's Avatar
3573
Drives: Austin Mini,MBGLK, Porsche 993
Use Apple TV Airplay to mirror....
Is the sound muted on your computer?
      02-09-2020, 12:43 PM   #3
FuriouslyFast
Drives: Miss Daisy
Nothing Apple over here outside my ipod, sorry.
No, the sound is not muted & plays fine through the laptop itself
      02-09-2020, 02:24 PM   #4
Salty Dog
Salty Dog's Avatar
3573
Sorry, I got nothing else. I'm all Apple so I'm tapping out.
      02-10-2020, 02:27 AM   #5
jimbobiggens
jimbobiggens's Avatar
Drives: 2013 335i xDrive
Can you try hooking the HDMI cable directly from the laptop to the TV? If the sound works that way, then the problem is most likely in the home theater receiver.
      02-10-2020, 08:19 AM   #6
FuriouslyFast
Drives: Miss Daisy
Yea, I figured out the receiver is being the PITA. I gave up & worked around it.
However, I then hooked my laptop up to my workstation (Via USB) on my desk & now I get no audio going to the speakers there out of the blue. This thing hates me
      02-10-2020, 09:15 AM   #7
Emilime75
Drives: 2010 335i E92 LeMans Blue
Check the playback devices and make sure HDMI is selected for your audio source.
If that doesn't work, update both your video and audio drivers. It's possible a Windows update is the issue, and updating drivers usually fixes it.
      02-10-2020, 09:49 AM   #8
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
Simple fix. Took me a while to figure it out as well. If the laptop is powered on, when you connect the HDMI, restart it after the HDMI connection is made.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
      02-10-2020, 10:55 AM   #9
FuriouslyFast
Drives: Miss Daisy
That was one of the many things I tried before posting.
      02-10-2020, 10:56 AM   #10
FuriouslyFast
Drives: Miss Daisy
All stuff that was already tried
      02-10-2020, 11:04 AM   #11
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
I would check your source. For example on my laptop, I use realtek source as my laptop speaker output but as soon I plug into HDMI, my source changes to Invidia speaker output.
      02-10-2020, 03:16 PM   #12
FuriouslyFast
Drives: Miss Daisy
It goes to the right source when either is plugged in. Not sure wtf is wrong as all settings are correct, drivers are good, blah blah. I have restarted, uninstalled & reinstalled & all that stuff many times. Still not working. Makes no sense as both worked perfect & now, out of the blue, neither works. I didn't even mess with anything to cause it.
      02-10-2020, 04:56 PM   #13
jimbobiggens
Are you using the workstation to play the video or the laptop?
      02-11-2020, 09:05 AM   #14
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
If you go into the mixer do you see the sound bars EQ going up and down with no audio sound output?
Did you try restoring to a earlier point?
      02-11-2020, 02:44 PM   #15
FuriouslyFast
Drives: Miss Daisy
Yes & yes
