03-30-2017, 08:02 PM | #1 |
Rep 11,128
Remote Controlled Cars
I had a few as a kid (Kyosho) and looking to get back into it, but not drop thousands of dollars. Mainly something fun to show my two year old, and maybe he'll enjoy it at some point also.
I saw a Kyosho RB6 for sale locally, priced at $200. Is that something decent? I hear that lipo batteries are a "must", but not sure if that's actually true or not. What else should I look at? |
03-30-2017, 08:15 PM | #2 |
Rep 5,983
I own a Traxxis it is quite good, all wheel drive truck gas powered that goes up to 45 mph. The nitro exhaust sound might be favorable to BMW enthusiasts. If you prefer electric, make sure to get one with a brushless motor, not sure if they've done away with brushed motors these days.
P111541.50 |
03-31-2017, 06:14 AM | #5 |
Rep 216
What exactly do you want, a road car or an off-road truck? Off-road is more versatile, but buggies are also started to get really popular because they hug the road and pretty damn hard to tip over.
I have a Losi XXX Short course truck, 2wd with a Mamba brushless motor. It can probably reach about 60mph when I max out the cpu, but it has multiple levels that you can run it at, beginner mode for your kid for example. A decent RTR setup will run anywhere from $200 - $350, depending what you get. If you spend around $300-$350, you could get an RTR kit AWD that probably has a brushless motor. If whatever you buy has a brushed motor, any LiPo battery that you run on it will kill the motor in no time just because of how much power those batteries expel. That's only the starting cost though, typically you'll want two to three batteries (Get good batteries, they're worth it) around $40-$60 each, then you'll need a charger and balancer. There are cheaper models that might be around $80 range, but the charge times are longer and usually only have one access port. Larger balancers can sometimes charge up to 4 batteries at once. I've always been a Traxxas (Nitro trucks), Team Associated (TC3 road race electric cars), and Losi buggies / short course trucks. So if you have questions feel free to ask. |
03-31-2017, 06:23 AM | #6 |
Rep 11,829
Drives: MY24 G01 AW Msport
where can i find these toys?
03-31-2017, 08:20 AM | #8 |
Rep 11,829
03-31-2017, 08:29 AM | #9 | |
Rep 216
Honestly though, they're a riot. I used to go to the indoor track with my buddy, his daughter, and my old man when I lived in MI. The initial cost up front is kind of a lot, but after that you pretty much just have to buy tires and spare parts if you crash. |
03-31-2017, 08:41 AM | #10 |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
I've got an E30 M3 from Tamiya that I built:
03-31-2017, 08:45 AM | #11 |
Rep 265
Pick up an RC-10 RTR. I was into RC off road racing when I was younger, and had my share of Tamica and then Kyosho (Ultima Carbon) buggies. I got back into it a few years ago with my son. I didn't have time to buld, so I grabbed two Team Associated RC-10 ready to run set ups and a couple of extra Li-Pos. It's a blast, they're fast enough to really enjoy in the back yard, at a soccer field, etc. My son digs it. We fix them together after our crashes, etc. There's also a ton of upgrades, so if your son starts getting into it for real, he can swap out just about everything on the car with better parts.
Tower Hobbies is a great place to start your search. Might not be the cheapest, but always has a wide selection RC10 rtr: http://www3.towerhobbies.com/cgi-bin...=LXFLVBBY&P=SM Here's the whole list: http://www3.towerhobbies.com/cgi-bin/WTI0297p?C=CA Last edited by Josh (PA); 04-01-2017 at 07:03 AM.. |
Axius4202.00 nyalpine907380.00 |
03-31-2017, 01:34 PM | #12 | |
998
Rep 3,784
Building the car from the ground up was really fun, given the level of detail (the car is 1/10 scale)... The trickiest part was painting the polycarbonate body, since you're painting the inside of the body and applying all those stickers (not decals). I also bought a E92 M3 GT2 body for the same chassis for future use:
Axius4202.00 |
04-01-2017, 12:03 AM | #13 |
Lofty
3458
Rep 849
I have a Team Associated TC3 that I built up, over the years. First 2 motors were brushed, then brushless. That motor destroyed the plastic gearing, so I replaced it with metal gears. Snapped the axle a few times. Went through quite a few tires and rims. Think it could do 80ish with a LiPo
Probably spent close to $800 or so on the car + the parts. Fun as hell, tho. |
Mr Tonka6058.00 |
04-04-2017, 02:15 PM | #14 |
Rep 598
Best to decide if you want to bash in your driveway or take it to a local track.
I 100% recommend lipo's. They are cheaper, lighter and have more capacity. Make sure your charger can balance them as well as charge and the speedo has a voltage cutoff. The RB6 is a pretty capable race buggy, parts can be hard to find and expensive. Check out TowerHobbies, A-Main Racing or Stormer Hobbies.
Jacob
2015 Chevy SS In 2011 E90 M3 DCT SSII Out Last edited by jaco; 04-04-2017 at 02:20 PM.. |
04-04-2017, 03:12 PM | #15 | |
is probably out riding.
6058
Rep 2,294
Got in to planes which was fun. Have a flying wing LiPo brushless set up with a 4" pusher prop that does over 100 in a dive. Prop sounds crazy at 24000 rpm.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
Aatish3458.00 |
04-04-2017, 03:21 PM | #16 | |
Lofty
3458
Rep 849
Tried getting into planes, but never really into them. Got a quadcopter that's fun to fly. Use it survey roofs too. Think I got it up to 850ft or so, before signal interference. Range extender is next upgrade.
F30 335 (FBO and BM3 OG)
991.2 C2 Range Rover Sport Diesel I4 M50 (coming soon) |
04-04-2017, 03:40 PM | #17 |
Warrant Officer
375
Rep 1,341
Had a Nitro Associated TC3, a Schumacher Fusion and also a Schumacher Menace.
Although nitro costs a bit to keep and maintain, they are much more fun than electric.
Deleted, ATM I/C and tuned by B.R.R.
Axius4202.00 |
04-06-2017, 09:37 PM | #19 |
Rep 2,111
I got two 2wd traxxas slash brushed rcs for my 8 year old and I. 7200 batteries and rapid chargers. SOOOO much fun!!!
I hooked one up to see if it would pull my 18mo... Yep!
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
04-06-2017, 09:51 PM | #20 |
Rep 1,700
The self-build kits were awesome fun. I was hooked as a kid. Anyone remember the Bigwig?
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black Current- 2018 Aventador S. Nereid blue Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i |
04-06-2017, 10:21 PM | #21 | |
6058
Rep 2,294
nyalpine907380.00 Axius4202.00 |
04-10-2017, 10:56 PM | #22 |
Güdentyte
1108
Rep 1,179
I have an electric and nitro hpi 1:10 scale.
Been playing with this one recently. They're just a blast.
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
