01-31-2022, 11:45 PM | #1 |
Rep 26
Windshield washer jets not spraying
Has anyone else had this problem? If so what solution did you find?
My windshield washer nozzles are not spraying, just barely dribbling out fluid. The reservoir is full, nothing is frozen (despite the cold temps), and the pump is working at least a bit because I can hear it and it does push out a little dribble.....but its not the blast it recently offered to clean the glass. Any help appreciated. Tacos |
06-03-2022, 12:12 PM | #3 |
Rep 26
Realized I never followed up on this.
The problem was that the windshield washer fluid was aging, not being used enough, and so it was gel-ing in the bottom of the tank, pump, and lines. I siphoned out the tank and the siphon tube pulled out globs of windshield washer fluid jelly. ick Then, I flushed the tank thoroughly with water and more junk floated up and out. Then I siphoned the tap water out. I then disconnected the washer fluid lines from the sprayers and let the old fluid in there drain out, globs of jellied washer fluid came out again. Flushed those tubes out, and reconnected everything back up. I filled the reservoir with distilled water and pulled the stalk to pump the water and whatever else might have managed to stay in the system out. I let it spray for a good while to make sure the pump and lines were well flushed with distilled water. Then I siphoned what was left of the distilled water out and refilled the reservoir with windshield washer fluid. Pulled the stalk to get the new fluid into the lines and sprayers to prevent possible future freezing. Then I washed the car to get the excess fluid off the glass and paint. Took about 30 minutes, start to finish. Easy job. Lesson learned: use your windshield washer sprayer system regularly. |
vreihen1615268.00 |
