      02-28-2019, 02:31 PM   #1
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
Turbo Cord Recall FYI
Not sure if anyone else received the recall notice on the BMW turbo cord. Pretty sure mine is fine as the normal plug to 6-30 adapter already blew up long back and was replaced, think this part is the reason for the recall.
Anyways, you have to bring the car and cord to the dealer for testing. While the X5 was at the dealer, I gave my SA the cord and said while I am here. He said I need the i3 too.....doh
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
      05-24-2019, 05:24 PM   #2
ohliumliu
Drives: bmw i3S REX
I had the same issue -- blown adapter -- with the turbo cord. The problem is none of my local dealers has the matching 240V socket to plug it in. They replaced the cord, but the same thing happened again. Have you had the same issue again?
I asked them about the recall too. Apparently they don't necessarily need the car. What they did was to check if the serial number was on a list. But they probably have strict procedure for everything, no matter how trivial it might be.
I am still working with BMW to get this issue solved. I am using a drier outlet for charging. It's hard to imagine the root cause is the power outlet. I did read some posts here talking about a surge protector. It doesn't seem to be a requirement based on my reading of the instruction manual. It's also hard to imagine the charger doesn't have a mechanism to protect it from unpredictable fluctuation from the grid.
Sometimes it gets frustrating working with the dealer and BMW. Everyone has a different answer, and they might all turn out to be false.
      07-18-2019, 09:29 AM   #3
arunprakash
Drives: i3
I have the same issue where the turbo cord is blown out now 3 times. Is anyone else having this issue? Did you get it resolved?
My charger was working perfectly until it was replaced as part of teh recall.
      07-31-2019, 04:59 PM   #4
ChefJerry
Drives: 2011 BMW 335d, 2018 i3 Rex
anyone hear back from the dealership? I have yet to take mine in.
      08-02-2019, 06:13 AM   #5
Obioban
Emperor
Obioban's Avatar
1613
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Is the non BMW branded TurboCord recalled as well?
I bought one, new, ~2 months ago.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
      12-07-2019, 10:21 AM   #6
ronbot
Drives: 2015 BEV, Arravani Gray, Tera
Exclamation
The issue is an incorrect capacitor was installed inside the main plugin box - in SOME of the early units, both BMW brand and AeroVironment/Webasto branded.
Aerovironment / Webasto branded:
https://www.homedepot.com/hdus/en_US...calls/2018.pdf
BMW provided chargers (serial number list included):
https://static.nhtsa.gov/odi/rcl/201...8V652-7122.pdf
