09-23-2019, 08:42 PM | #1 |
Rep 4
Planning to buy a I3
anyone where can I take the car to do the codes ... SF Bay area
Allow 2.4 Gallon Tank Capacity Allow REX anytime below 75% “Hold Mode” thanks in advance |
09-24-2019, 06:23 PM | #2 |
Rep 56
Just purchase the Bimmercode app, then select a OBDII code reader from the selection within the app.
You will then be able to set this to 75%, which was the first thing I changed before even driving mine, along with any number of other tweaks. Best part of doing it yourself is that is cheaper and that you will think of other things you want to change as time goes on and it will be as simple as connecting the app to your car. Brian
///M3 2008 Coupe - Melbourne Red, BMW Performance front splitter and rear spoiler, Akrapovic Evolution Exhaust w/carbon tips, MS StageII intake, Vossen CV7 20"x9" front 20"x10.5" rear, AiB LED Halo, full interior LED lighting, ZHP shift knob (lighted), black grilles & side lights, 09+ NAV controller, ...
10-24-2019, 05:47 PM | #3 |
Rep 423
^^ This - Bimmercode is awesome and painless.
As mentioned above, Bimmercode works with several adapters. I bought the "Veespeak" bluetooth one that was linked from their site was about $30 off Amazon. The app is about $30 or so, that is just a 1 time fee. Several years ago, I purchased something called Carly, its a POS. They switched to a subscription model on the app, and also the bricked the OBD connector running an update to it (this happened to several people if you read the forums & amazon reviews). I do NOT recommend the Carly reader. And if you're super hacker, wait for someone to chime in to tell you to use some free software, laptop and obd connector for 15 bucks to code everything. But thats gibberish to me. Enjoy!
11-04-2019, 10:02 AM | #5 |
Rep 577
I just did the 2.4g tank and HSOC code on the bimmercode app and couldn't be happier. Just took the i3 on it's first long trip to San Diego and was able to use the HSOC during the drive. Quick question to more experienced users of this feature, does it take a moment to disable HSOC? I programmed HSOC to one of the numeric dash buttons and used it when the battery level went down to 65%. Used it for about 50 miles just to try it out and then tried to disable it and had to do it in several tries before seeing that it did turn off. Just wondering if I had to wait a moment to see it turn off. Anyway, thanks for any replies. Cheers!
"What a car.... what a masterpiece...." Jeremy Clarkson on the E92 M3
2008 Alpine White E92 M3 2019 Mineral Grey i3 REX |
11-04-2019, 10:30 AM | #6 |
Rep 47
It does take a bit to turn off the generator. Once you request the shut down it can take a moment to stop and switch back to batteries. I have seen different results depending on if the car is parked or moving. Just hit the switch once and wait.
11-04-2019, 01:30 PM | #7 |
Rep 577
cool. any other i3 rex recommended hacks from bimmercode? thanks.
11-04-2019, 06:21 PM | #8 |
Rep 47
I did the angel eye brightness to 100% and turned on the AM radio. I tried to setup the rear fog light but it turns out that the physical switch needs to be changed as well.
I also reduced the amount of side mirror tilt when in reverse. I also changed to the startup graphic the Mini logo. I have only touched the surface. I was thinking about Quizdell TJA that auto drives the car in some conditions. But I am sure that bimmercode does not code that so you will need some other software if you want to turn that on. |
11-04-2019, 10:39 PM | #9 | |
Rep 2
Does anyone know why that is? is there a better OBD adapter I should be using?
BMW i3 REx - TeraWorld Pkg
MODS: Satin black two-tone wrap, carbon fiber M mirrors and accents, Bimmercode hacks UPCOMING: Lowering springs, spacers IG: ShagnWagn |
11-07-2019, 11:16 AM | #11 | |
Rep 577
