01-13-2019, 04:11 PM | #1 |
Chicago BM'r
Rep 5
2015 i3 REX
While installing snows I asked if they could install lower springs and was cautioned that it could invalidate the warranty.
1) Does anyone know for certain if this is true of if the tire installer was merely being conservative? 2) Any feedback on lower i3 springs in terms of drive-ability, performance, parking (scraping lip on a concrete bumper in public garage)? |
01-13-2019, 07:39 PM | #2 | ||
Rep 2,561
The overall vehicle warranty will not be impacted, but if you blow out you shocks after installing too short a spring, replacement shocks will likely be sponsored by your wallet, not BMW's. Quote:
Generally speaking, shocks should have a piston length and valving that match the spring rate and height. Every time I had modified my cars' suspension, it usually included performance shocks + springs, as well as sway bars and alignment. i3 handles so poorly (relative to other BMWs), that swapping out springs alone would be a drop in a bucket. However, if you are just going for looks, that should do the trick. HTH, a
'19 TM3P (BK/BK)
Tags |
spring lowering |
