02-07-2019, 12:18 PM | #1 |
Rep 5,992
Encrypted wired garage door button
So my garage door wired button mounted inside the garage is encrypted making it difficult to add a device that can open the garage using an app by simply attaching it to the terminals. I can understand encrypting the wireless transmitter to prevent hackers from gaining access, but what would be the reason for encrypting the wired button inside the locked garage? If I break into your garage and press the button the door will open whether it is encrypted or not lol.
02-07-2019, 12:23 PM | #2 | |
Space Force - 4 Star General
11461
Rep 3,264
02-07-2019, 12:26 PM | #3 |
Rep 2,526
From a programmer standpoint, I can see doing this for one reason, to provide a single interface that supports multiple uses. By encrypting data transfer, they can use the same connector whether its inside, or outside the garage.
Annoying, yes, but it makes sense. |
02-07-2019, 01:05 PM | #5 |
Rep 5,992
I'm using a no name brand app controlled garage door opener so they are sending me a part so it will work with my opener. Regarding the stapler cutting the insulation on the earlier post probably should get that fixed it is a fire risk. The unencrypted door alerted you to the problem lol.
02-07-2019, 01:40 PM | #6 |
Rep 1,340
Encryption makes it hard to access the meaning of the message, not the message itself. Encrypting a push of a button (one bit of information) makes no sense: there's just nothing to dig. A complex signal (a "message") can prevent coincidence (which can be guessing as well), as described earlier, but you don't have to encrypt it: just have it sufficiently complex (like a "strong" password).
02-07-2019, 08:34 PM | #7 | |
Rep 5,992
02-07-2019, 08:45 PM | #8 | |
Rep 2,526
https://www.amazon.com/Arrow-Fastene.../dp/B00004Z2JX or even this if you're careful: https://www.homedepot.com/p/DEWALT-4...841D/206210812 |
DETRoadster11460.50 |
02-07-2019, 09:35 PM | #9 |
Rep 760
I'm curious what the garage door brand is. Never heard of one encrypting the button push.
14 Audi S4 (sold)
16 BMW M3 (sold) 16 VW Golf GTI (sold) 20 Tesla Model 3 23 Audi R8 (on order, never came ) |
02-08-2019, 01:22 AM | #10 |
Rep 5,992
02-08-2019, 12:17 PM | #11 |
Rep 5,992
So the support got back to me and they have a wireless adapter instead, so I won't be needing a staple gun. It basically works like the wireless remote but attaches to the camera app controlled component. Update: so I received the remote. It is a hacked chamberlain remote with two wires sticking out that connect to the contacts on the remote where the button connects. This way the app controlled component can effectively press the button on the remote via the wire and the remote is programmed to the opener.
02-14-2019, 09:48 AM | #12 |
Rep 1,268
I have dealt with this situation.
First make sure your opener does not have terminals on the actually opener which allow for a momentary contact (pushing a button) to open the door. If it does just hook into those terminals. If it does not, and some do not since they only work with the rolling code buttons and openers. If your does not have the extra set of contact, take the coded button off the wall and take it apart, and look at the PCB and look for where the button to the electrical circuit is connected and solder wires to the opposite sides of the button. I did this method before I realize my open had the extra contact, it is one thing the internet did not share that some opener has both methods, It wasn't until my open got killed during an electrical storm and I have to replace the controller I found the extra contacts and use them verse hacking the wall button. Here is a link on doing this http://cocoontech.com/forums/topic/2...comment=174052 This discussion show where to solder the wires on a genie garage door opener this is the open I had, the controller board in the opener also had extra contract next to the where the wall button hooks in. this can be done on other openers as well. https://forums.indigodomo.com/viewto...p=57235&t=7364 Last edited by Maestro; 02-14-2019 at 10:01 AM.. |
02-14-2019, 10:02 AM | #13 |
Rep 5,992
Thanks for the info. Everything is working with the universal remote hack they sent me. Now I just need to get a new bottom seal as rain water is making its way in. I tried setting the close position lower but I think this is putting more stress on the door.
