      07-25-2020, 08:19 PM   #1
Michael S.
Michael S.'s Avatar
Drives: BMW i8, 650M sport, 230i, DB9
charging extension cable for 110v
Could somebody please recommend a good extension I could use to charge from wall outlet 110v , I know regular extensions don't work( I've tried them) and the cable is a bit short to where my wall charger is, I have to get i8 too close to a wall to charge, Am afraid one day in overdue it and got the wall, would really appreciate if anyone can post a link to a safe and tracks extension cable for 110v(wall outlet). Because I know that every couple of weeks it's good to charge to 100% to maintain life of batteries.
      07-25-2020, 08:40 PM   #2
stressdoc
stressdoc's Avatar
Dominica
617
I have a cord that does not work and one that does. I am guessing that the system requires high amp, heavy gauge cord.
      07-25-2020, 10:30 PM   #3
Michael S.
Michael S.'s Avatar
Would you happen to know the specs on the cord that works?
Thanks
      07-26-2020, 08:50 AM   #4
2sak2furious
2sak2furious's Avatar
Drives: 2019 i8 coupe
Got mine on amazon - it’s under J1772 extension cords 40 amps...I got a 40 feet made by jlong but that one is not available anymore. No problems so far.
      07-27-2020, 07:24 PM   #5
HawaiianPunch808
Drives: BMW I8
Been using this one for over a month now. I'm not close enough not to need one so hoping it continues to give me no issues.
AmazonBasics 16/3 Vinyl Outdoor Extension Cord, Green, 50 Foot https://www.amazon.com/dp/B07N4L1F9Q..._T.2hFbZ8N4ED8
      07-28-2020, 09:00 PM   #6
char1982
Drives: 2014 i8 white w/ frozn gray
I use this one
ProStyle 25ft. #10 SJTW 3... https://www.amazon.com/dp/B01F2RFSFC...p_mob_ap_share
      08-04-2020, 12:30 PM   #7
Michael S.
Michael S.'s Avatar
Originally Posted by char1982 View Post
I use this one
Thank you, and may I ask how long have you been using it, and if no hazardous overheating in cord?
Thanks Mike
      07-21-2021, 03:47 PM   #8
Game
Game's Avatar
Drives: G87 M2 (sold)
Bump.
Wanted to get some more opinions here.
      07-25-2021, 08:26 PM   #9
char1982
I’ve been using it for a few years. Never even gets warm.
      09-28-2021, 08:50 AM   #10
zorgzx
zorgzx's Avatar
Denmark
21
Drives: I8 Coupe
In most stores they will have 2 grades of cord, one of them with more costly heavier grade wire.
I have used one such for years.
If not, just go and turn down the charging power to mid or low setting.. problem solved.
I actually recently found a extender for the charge stand we use at work. real lifesaver when lots of cars want to use the same stand.
https://evchargeplus.com/shop/ev-cha...2-32a-1-phase/
      10-03-2021, 11:21 PM   #11
tommyb13662
Drives: 2009 135i
If you are in the USA. Walmart sells a 25' extension cord that uses a claimed 14 gauge wire($19). I bought one and charged the car with it a few times zero issues. To the touch I felt no heat off the extension cord at all. The small short pigtail on the charger itself that was plugged into the extension cord was slightly warmer to the touch. But the extension cord itself was cool as the outside temp.
      11-02-2021, 11:10 AM   #12
rastaman777
Drives: 2020 i8 coupe,2019x5,2019 740i
extension cords
Ditto for me...I've used a variety of extension cords. Pretty much whatever was lying around, in terms of 'heavy duty'. Most worked without issue, no over heating noted at all.
