      05-12-2019, 08:01 PM   #1
studstud1
Drives: 2015 BMW i8
Charger
What is the best home charger for a 2015 i8?
      05-13-2019, 12:02 PM   #2
evanevery
evanevery's Avatar
1113
Drives: iXM60, i8 Rdstr, M4, i7 M70
The 120V cord that comes with the car.
The battery in the i8 is so small (and the charging rate is also artificially limited by BMW) that it doesn't really make sense to invest in a Level 2 charger for the i8.
Any generic charger will also work fine. Wouldn't be much of an "EV" implementation if it required some sort of BMW specific charger....
      06-02-2019, 03:53 PM   #3
FLYIN'
FLYIN''s Avatar
203
Drives: M2 Comp, M550i, X545e
Had a GE charger first (lowest cost level 2 at about $350) but then switched to the ChargePoint as it has Wi-Fi built in. Although it can't differentiate between our three PHEV's. Some utility companies used to subsidize the installation. I don't think many do any more.
https://www.chargepoint.com/drivers/home/
Ended up putting the GE in our summer house.
The 120v chargers that come with the car take forever to charge. Ok for overnight charges but at 8-9 hours versus 2 hours for a level 2 it's worth spending the money on a permanent installation.
FLYIN'
'20 BMW M2 Competition
'20 BMW M550i
'21 BMW X5 45e M Sport
      06-03-2019, 04:11 AM   #4
Iain123
Drives: I8
Don’t pay too much attention to different brands other than how waterproof they are and the quality of the plug plastics. A wall charger doesn’t do much more that your bedroom light switch. Inside there is a large relay/isolator (electrical switch) and a circuit board. When you plug in the car, there is a signal goes back wall box to tell it to energise the relay and allow a straight through mains connection to the car and well that’s about it! Although there is also an adjustable setting inside the wall box that communicates the size of its components (16/32amp) to the car so the car can adjust the current accordingly. (the i8 can only take 16amp but best get a box that can do more)
The wall box should cost less than $300/£200 but we are all getting screwed as its 'new' tech.
