      04-06-2010, 04:44 PM   #1
david @ eas
david @ eas's Avatar
▀▄ eas | DICE - G2 DCR-50 ipod & iPhone Cradle for your BMW
Gentlemen,
We've got a new product out from Dice that you'll surely want to take a look at.
Your iPod should not bounce around in the glove box! Wouldn't it be great if you could easily view caller ID on your iPhone? Designed with the in-car environment in mind, the G2 Cradle safely holds iPod and iPhone models in plain sight. Rotate it, tilt it or angle it anyway you want it; the G2 cradle will adjust to your desired viewing angle. The compact dimensions wont obstruct your interior space or your view. When your not using it, you will hardly notice its there.
Compact, sleek and to the point, the DICE G2 cradle is designed to flow with the contours of the iPod and blend with the interior of any vehicle.The classic, OEM-like design has no neon-lights and features a small brushed aluminum DICE logo. With AMPS and iGrip patterned mounting holes, the mounting possibilities are nearly endless so we leave the decision to you. We recommend KUDA mounting solutions. The included short and long mounting bases give you access to larger connectors sometimes found on car integration kits.Included are 6 interchangeable holders to support popular iPod and iPhone models. Want to swap your iPod Classic and plug in your iPhone 3G? Slide one holder off and the other one on and you're ready to go! Wether it's your BMW's factory iPod kit, DICE's Silverline Pro or even just a simple charger, you can connect it to the G2 Cradle!
Features
Height: 2.75", Width: 2.60", Depth: 1.90"-2.50"
Simple pass-through connection
Compact and easy to mount
Fully adjustable
Includes 2 mounting bases and 6 interchangeable holders
http://www.europeanautosource.com/pr...oducts_id=3146
If you have any questions, please feel free to ask!
Search this Thread:
Advanced Search
