      12-04-2018, 12:17 PM   #1
jmg
jmg's Avatar
19118
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.88]
2018 F80 M3 CS  [9.90]
2019 i3 BEV  [5.00]
REX stopped turning on after coding
I used Bimmercode to turn on the REx manually (after 75%), but I've noticed that when my range gets low, the REx does NOT turn on by itself anymore. Anyone else encounter this?
I'm wondering if it was this setting:
Range Extender activation battery level
Available in KOMBI FPK_I12, KOMBI_I01_F56
IG: Raging_G82
      12-04-2018, 01:13 PM   #2
afadeev
afadeev's Avatar
1186
I don't use Bimmercode, but there is a value that can be set that dictates when REX kicks in automatically. Default value is 6 (% of SOC remaining).
Alter Range Extender activation battery capacity level:
3000 ->SOC_HOLD_POS werte = hex value xx
Units are 0.5% -- default = 0C which is 6% ie. 18 = 12%
If you had accidentally set it to a lower value, or 0, that would produce the outcome you are describing.
a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS)
      12-04-2018, 01:23 PM   #3
jmg
jmg's Avatar
19118
2019 i3 BEV  [5.00]
a
Thanks I'll check that out!
IG: Raging_G82
      12-05-2018, 11:17 PM   #4
jmg
jmg's Avatar
19118
2019 i3 BEV  [5.00]
a
Mine was set to 12% so I set it back to 6%. I'm going to let the battery go low to see if it kicks in.
IG: Raging_G82
      12-09-2018, 02:44 PM   #5
PBNB
Drives: 2015 i3 REX
I used bimmercode to change mine to 12% but it didn't work either. The little pointer is sitting at 12% on the SOC gauge but the REX doesn't start. I haven't let the charge get back down to 6% but I expect that it will start then. Seems that we can't change this value with bimmercode.
jmg19118.00
      12-12-2018, 06:35 PM   #6
jmg
jmg's Avatar
19118
2019 i3 BEV  [5.00]
Confirmed. I coded it back to 6% and the Range Extender now turns on automatically at 6% again. Hopefully the next update will fix this.
IG: Raging_G82
      06-21-2024, 11:04 PM   #7
yfenke
Drives: BMW i3
Who do you know what’s the problem about I have coded the soc range manually, but I clicked it, the rex don’t run.
      08-04-2024, 10:17 PM   #8
msnyderfoto
msnyderfoto's Avatar
Drives: BMW 2014 i3 REx
2014 i3 REx  [0.00]
2014 i3 REx  [0.00]
REX coding
In my 2014, the REX was coded to be MANUALLY available once the SOC was below 75%. It won't come on automatically, you would need to assign a media button preset to operate the feature. The auto 6% is the factory standard.
Search this Thread:
Advanced Search
