      12-17-2020, 09:59 AM   #1
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
Drives: G26 i4 M50, F11 M550d, E70 X5
DTC-button project - need ideas
One of the most irritating thing with the i3 is lack of the DTC button on the center console, so I decided to try to retrofit DTC button.
I have checked the wiring diagram for i3 and i8, and they are identical. That would mean, that the switch button panel on the i3 also include DTC function, even when it miss the button.
I ordered an i8 switch panel, and everything works, except of the DTC button off course.
I´ve checked the BDC coding options, and found this from factory:
FesDtcKopplung - nicht_active
Switchboard_ai_a_enable dtc - active
Switchboard_ai_b_enable dtc - active
Switchboard_ai_c_enable dtc - nicht_active
Switchboard_ai_d_enable dtc - nicht_active
Switchboard_DTC_variant - nicht_active (or something)
FesDtcTasterFehldruckHeilung - nicht_active
FH_taster_einstufig - nicht active
FH_taster_einstufig_rear - nicht_active
After changing all this to active, the button works, but ut just shows the driving mode in HU screen. So if the driving mode are in Sport, it just shows Sport in HU as when you enable the sport with the Eco-Sport switch.
Have anyone idea?
OEM+ customization is the way to go!
      02-09-2021, 09:21 AM   #2
i3s_Dan
i3s_Dan's Avatar
Netherlands
Drives: BMW i3s
Hi, interesting project!
Where you able to activate DTC button?
Daniil
      02-11-2021, 01:56 PM   #3
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
Daniil
Haven't seen on it for a while, since im working on soft close door retrofit (planning of doing it at saturday, and then work more on the DTC).
      02-12-2021, 08:49 AM   #4
i3s_Dan
i3s_Dan's Avatar
Netherlands
Drives: BMW i3s
Looking forward to see your progress for both projects!
I'm study now how to retrofit 360 degree view system from i8 to i3. If you ever seen anything related, please share.
      02-13-2021, 03:26 PM   #5
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
Im figure out the same retrofit as well. Im not sure where I would put the front camera yet, but I will keep you posted when im starting the project. Startet on the soft close today though.
      02-15-2021, 09:03 AM   #6
i3s_Dan
i3s_Dan's Avatar
Netherlands
Drives: BMW i3s
Thanks!!
