11-07-2018, 09:30 AM | #1 |
Rep 75
Wireless Phone Charging in the i8
Hi,
Does anyone know if it's possible to fit a BMW wireless charging cradle to the i8? It looks like there's some sort of standard mobile phone holder in the armrest, but I'm not sure if the adapters are compatible. For example: https://shop.bmw.co.uk/bmw-uk-respon...-tray/2449887/ Thanks, |
11-10-2018, 10:17 AM | #4 |
Rep 578
I wonder if this would fit in that armrest have not measured yet. There is a nice cable feed channel from the front compartment it can plug into.
https://www.amazon.com/Wireless-Char.../dp/B01GQRP59G Or this https://www.amazon.com/FASTPAD-Ultra...2XAGGGFRBYPABY Or this https://www.amazon.com/Viotek-FASTPA...vw_txt?ie=UTF8 |
11-14-2018, 03:00 PM | #6 |
Rep 13
I used this and it works great. I mounted it to the right of the shift stick on the side where it has a slight curve and used a usb lighter adapter to connect the power.
https://www.amazon.com/gp/product/B07D1F4JD1/ Will post a pic when I get home. |
MajorJump9.00 |
11-14-2018, 03:08 PM | #7 | |
Rep 75
Does the magnet hold the phone ok? |
11-14-2018, 04:05 PM | #8 |
Rep 13
Yes it is magnetized on outer edge of mount. There is a metal ring that comes with the unit that you can mount onto the phone. I have found, however, that the internal metal content of my Galaxy S7 will adhere to the mount without having to use the metal ring. Using the metal ring will provide a stronger support. I have tried iPhone the same way, but it won't stay on, will need the metal ring to be mounted on the phone to work properly. The ring will hide just fine under most cases.
MajorJump9.00 |
11-14-2018, 04:35 PM | #9 |
Rep 1,904
Its not wireless but here is my solution. Its a 3D printed holder on a RAM ball mount. The phone just slips straight down onto the integrated USB connector. It holds the phone securely, in full view yet relatively out of the way while in motion and is very easy to install/remove the phone. Just drop the phone in or slide it up and out (gravity does the job). (The angle of the photo makes it look closer to the shifter than it actually is - I can work the shifter with a "full hand" and not come close to any interference).
An adhesive backed RAM ball mount makes pretty good use of that otherwise pretty useless cavity just fwd of the shifter. The USB cable is tucked behind the console and into a flush mount USB charger permanently inserted into the aux power port under the glove box. Since the aux power port under the glove box is normally always hot, I rewired it to an AUX power circuit in the fuse box (its right there as well). This way the whole mounting system (inc the 12v USB charger) can stay in place all the time and I don't have to worry about draining the 12v battery. It also offers high power USB charging (2.4A). If I do want to remove it, its only a single thumbscrew on the ram mounting arm. Only the ball stays behind in the cavity...
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 11-15-2018 at 10:27 AM.. |
11-14-2018, 08:50 PM | #10 |
Rep 578
So both of the ones above fit, but the bigger one sits almost perfectly where the tray insert sits when you remove it and the phone can sit directly on top of it. It seems to work very well.
https://www.amazon.com/FASTPAD-Ultra...2XAGGGFRBYPABY |
11-14-2018, 09:07 PM | #11 |
Rep 13
Here are a few pics of the mount. I purchased a lighter plug adapter that added 2 extra lighter plugs as well as 2 high powered USB ports. I run out of this plug a dash cam, radar detector, and the wireless charger.
The mount attaches using a 3M sticker. Pretty sturdy, it won't get knocked off. Last edited by imaeyeguy; 11-14-2018 at 09:15 PM.. |
11-15-2018, 10:25 AM | #12 |
Rep 1,904
Whats the thing in your acc port (looks like a hub)?
Is the port rewired for ACC power (instead of always on)? Would a small, dual port, flush mount 5V charger not have worked? https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The Fuse Box is right there so if you have a bunch of stuff your trying to permanently power from the ACC port (i.e. radar detector), you can use one of these instead and completely hide the wires: https://www.amazon.com/10-Pack-Add-c...micro+fuse+tap
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 11-15-2018 at 10:31 AM.. |
11-15-2018, 11:12 AM | #13 |
Rep 1,904
BTW - Wireless charging is convenient, but when in the car you might want/need more power.
The highest powered wireless chargers typically top out at 0.8A (although the spec permits 1.6A) while a good USB charger will deliver 2.4A. USB can charge three times faster as it provides three times the power. This is particularly important if you are running high demand applications while charging. Anyone who has tried to run Waze while wirelessly charging has likely experienced the "losing battle". (My GMC has a built in wireless charger in the armrest)... Last edited by evanevery; 11-15-2018 at 11:18 AM.. |
11-15-2018, 01:35 PM | #14 | |
Rep 211
11-15-2018, 04:41 PM | #15 |
Rep 578
I have the same concern and I like your idea. I was thinking of something that would be a little sticky and thin, so a thin film of silicone may be perfect. I haven’t had a chance to try yet.
11-15-2018, 10:37 PM | #16 | |
Rep 13
It is a 90 degree elbow hub with 2 lighter outlets and 2 USB ports. My radar runs off a lighter outlet. You are right that accessing the fuse box is a cleaner look, but this option was path of least resistance. When you are sitting in the passenger seat, you really can't see all the wiring, Most don't even notice it's there except for the red led light. The pic was taken from below the unit, that's why the wiring is visible. |
11-15-2018, 10:49 PM | #17 | |
Rep 13
11-15-2018, 10:53 PM | #18 |
Rep 13
I actually bought the "tray" wireless charger, but decided against it because I couldn't figure out how to get micro USB into the center armrest and still keep it clean looking without wires running into it from the side.
11-16-2018, 07:43 AM | #19 | |
Rep 578
It’s a nice small touch, I used to dangle the cable out under the cover in my coupe. |
Louv300.50 |
11-17-2018, 11:13 AM | #21 |
Rep 211
OK... so I wrapped the charging pad in non slip silicone and it works a treat! Wires hidden through the small channel between the front and the rear armrest covers. Phone no longer slides off and an added bonus is that I can charge my display key on the same pad (although clearly not at the same time)!
11-17-2018, 12:19 PM | #22 | |
Rep 578
