05-11-2018, 09:45 PM | #1 |
Rep 310
Fuel door locked me out
It seems that a lot of i8 owners have had an issue with the fuel door not unlocking.
My experience has been that after a long drive when things are hot the fuel door remains locked and the progress percentage on the gauge cluster stops at 25%. When the car is cold and I just drive a few miles to the gas station the fuel door unlocks with no issues. My question is about the fix. Some have said that a software update has solved the problem. Others have said that the fuel tank must be removed and a pressure switch replaced. They also mention disconnecting coolant lines to get the fuel tank out. Does anyone have a real world experience and exact fix they can report? |
05-11-2018, 11:07 PM | #3 |
Rep 687
Drives: Ferrari 458, BMW i8, Acura NSX
I went through this. It's an ordeal. Took it in twice. First they replaced fuel door and second time fuel sensor. Knock on wood it's been fine last thousand miles. I haven't done a long trip though.
05-12-2018, 12:53 AM | #5 |
Rep 60
Mine stuck at 25% too when it was out and about but occasionally would open at home.
Needed the pressure sensor fix. The tank has to be dropped down and the coolant lines run underneath it so have to be disconnected as part of the fix. |
05-12-2018, 12:57 AM | #6 |
Rep 487
Happened to me. Dealer came to my house and took it in for service. It was a pressure sensor they replaced and it has been fine so far. But I'm nervous to let the fuel go down to empty.
2019 M850i (ED Mar 2019) Sonic Speed Blue/Fiona Red/Black
2018 X4 M4.0 blue/white (wife?s) 2015 i8 (Feb 2016) White Pure Impulse (SOLD) 2015 M4 (ED Aug 2014) Austin Yellow/Sakhir Orange, EXEC, DCT, LED, Driver Assist (SOLD) 2015 328GT (ED Apr 15), White, loaded (Wife's) 2012 X3 2.8, Dark Blue/Red (Wife's SOLD) Retired: 2011 535i, ED / 2008 335is / 2006 525i ED, 2003 525i ED / 2002 Audi TT |
05-12-2018, 07:03 AM | #7 |
Rep 687
It's an annoyance to say the least. Oddly, the NSX is a hybrid as well and doesn't have to depressurize the fuel door. Not sure why BMW went through the trouble. The i8 mechanic explained it to me but I wasn't totally buying it.
05-12-2018, 07:25 AM | #8 |
Rep 174
Happened to me just once, but I was extremely low on fuel. Never happened again since.
Don't fret, it's very simple to pop the boot and pull the manual release if it is causing issues until fixed. |
05-12-2018, 08:42 AM | #9 |
Rep 310
Thanks everyone for the information.
The closest BMW dealer is 1 1/2 hour drive away and the thought of probably leaving the car for a day or two doesn’t appeal much to me. I tried placing a small plastic plug into the hole on the gas door that would keep the locking pin from engaging and just figured that I didn’t need to lock the fuel door. Seemed like a good idea. But when the locking mechanism discovers it can’t lock the door then the check engine light illuminates. So I guess I’ll wait until I need something additional serviced at the dealer and use the cable release in the trunk until then. |
05-12-2018, 06:32 PM | #10 |
Rep 1,177
As far as I know, the i8 has a fuel bladder instead of a tank. That is to prevent a layer of air sitting on top of the fuel, which would eventually render it incombustible. I’ve had that happen with one of my classics. Massive nuisance: drain entire tank, replace with fresh fuel, crank engine until all the bad stuff has been sucked through the pipes, hope it fires when the fresh stuff arrives at the engine.
Hybrids are potentially susceptible to that. I haven’t been to a gas station in months. I think the fuel door release mechanism is there to allow for gradual pressure equalisation rather than a shock event - which would be what the manual release does. |
05-13-2018, 11:38 AM | #11 |
Rep 310
Never heard of any car other than the Toyota Prius having a fuel bladder and I think they discontinued the idea about 8 years ago because it didn’t work as designed. The intent was to reduce fuel vapor from building up in the tank and thereby reducing hydrocarbon emissions. Now they use a vapor recovery system probably similar to the i8. The bladder was not intended to keep the fuel from oxidation and going bad from exposure to the air.
I’m not really sure what BMW is doing on the i8 but I really doubt it’s a fuel bladder. You should probably burn some gas and try to put some fresher gas in the tank on occasion. |
05-13-2018, 11:55 AM | #13 |
Rep 407
My dealer said the same - something to do with proximity to the LiOn battery, Stainless Steel is safer in the event of a battery fire.
2014 i8
2002 x5 4.6is |
06-20-2018, 02:57 PM | #15 |
Rep 310
Just received a letter in the mail from BMW.
They have issued a component specific limited warranty extension for the Fuel Tank Pressure Sensor. The warranty for the fuel tank pressure sensor has been increased to 10 years/ 120,000 miles. This is for “committed to delivering the ultimate in product satisfaction to our customers” |
06-21-2018, 08:48 AM | #18 |
Rep 465
got the same letter. that was impressive
06-21-2018, 03:50 PM | #20 |
Rep 328
01-08-2019, 03:41 PM | #21 |
Rep 211
Had this same issue today, couldn’t fill up, the percentage never getting above 25%. The first time this happened my fuel wasn’t that low so I drove home and the following day all was well. Today the fuel was really low so I chose instead to drive to the BMW dealer who was half a mile away. I’m told that it is the pressure sensor so I’ll find out tomorrow!
Whether I get a letter or not is up for debate! |
01-08-2019, 04:01 PM | #22 |
Rep 407
If you use the manual release, be gently with it. I found to my cost that the cable can be pulled clean off the flap. If this happens you can still close and open the fuel door but it won't lock.
I haven't got round to investigating a solution yet.
2014 i8
2002 x5 4.6is |
