02-23-2023, 07:39 PM | #1 |
Rep 3,788
LED Headlights swap to Laser Headlights, plug and play + coding?
Was wondering if anyone knows... If the LED Headlights we're swapped to the Laser Headlights, would they be plug and play + coding?
For production line purposes, I would think that the harness / plug(s) / connector(s) are the same on both of the headlights, but not 100% sure. Any insight is much appreciated. TIA. |
02-24-2023, 12:57 AM | #2 |
Rep 5,733
Drives: '24 iX50; '23 i4 M50
Did you already end up with an i4, or you considering getting one? I replied to you over on the i4 forum. Sorry, not sure the answer to your question, but lasers are a non-negotiable IMO
https://g20.bimmerpost.com/forums/sh....php?t=1989557
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
02-24-2023, 02:16 AM | #3 | |
Rep 3,788
Glws on your i4. |
02-24-2023, 05:10 PM | #5 |
Rep 352
From what I've been able to find out the modules are in the lights themselves so should be just plug in and code .... However .. it's so brutal expensive after market that I can't see why you would do it. A 1k option at production was like over 3500 aftermarket... If you find a cheaper option let me know. It's the one feature I didn't get and really wish I did
11LMBiSTT1548.50 |
02-24-2023, 05:14 PM | #6 | |
Rep 3,788
Yeah, I found the person/link to the retrofit. It's plug and play + coding.
I can't stand the Base LED Headlights, so will eventually do a retrofit. |
02-26-2023, 07:32 AM | #7 |
Rep 352
So not sure how much I trust the descriptions on ali but I'm seeing headlight housing and modules but can't ascertain what features the modules have. Also curious as to if corning can be added just by changing the modules etc . I'm sure it's not that easy but here are some links I found... But they want 2400 for just the housing and the modules are another 200 but not sure if they are cornering etc then you likely still need an adaptive bulb assembly which god only knows how much .. I think it's a bit of a fools errand but maybe someone will figure it out. Maybe a junkyard will end up with something. I imagine the g22 lights fit so I'm hoping to find adaptive leds or lasers 2nd hand eventually
02-26-2023, 10:43 AM | #8 | |
BMW Aficionado
1363
Rep 1,827
That being said, I was happily surprised at how good the standard LEDs were on the G26 i4. Personally I always order my cars with top-spec headlights, but for her we didn't have the luxury of waiting for a P1 build as we had already waited 6 months for a G30 that never arrived to USA after build by the time we decided to switch to i4. |
02-26-2023, 12:37 PM | #9 | |
Rep 352
02-28-2023, 05:54 PM | #11 |
Rep 352
02-28-2023, 06:31 PM | #12 |
Rep 4,144
that's why i'm pleased to have the darker laser that swivels but i can't believe laser is darker (not by much but noticable as i don't have the best eyesight)
03-01-2023, 08:49 AM | #13 |
Rep 331
Drives: 2022 i4 eDrive 40 mSport
I know we covered this in an earlier thread, but my edrive 40 produced in August 22 has swiveling LED headlights. I feel lucky that I got them.
03-05-2023, 04:11 AM | #14 |
Rep 352
I would be curious to get pics of the lights, if you can get part numbers and pics of the modules etc. Maybe we can find them 3rd party
smatanovic197.50 |
03-06-2023, 08:43 AM | #15 |
Rep 331
