      09-08-2020, 07:37 AM   #1
WidowMaker03TX
Drives: 2016 i3 REx
Is Coding My 2016 i3 Rex A Good Idea For Daily Commutes?
Hi Guys,
I would like some advice before I execute on an idea. I recently moved out of a house to an apartment until my new home is being built. This has put me in a five-month temporary position of not being able to charge my i3. I am also working from home but soon I will have to start my daily 62-mile round trips and there are no charging stations at my job. There are two charging stations within 10 miles of my apartment. The charging stations are somewhat slow, and it takes about 5 hours to fully charge my car.
I’m think about coding my i3 to have the REX hold at 75 percent option. I think this would solve my daily use problem. How much stress would this put on the REX as I am sure it was not designed for daily use?
2016 BMW i3 REX, Fluid Black, Tera World, 20" Wheels, Tech/Driving Assist Packages, 37K miles
      09-08-2020, 12:32 PM   #2
BL 5
Drives: 2015 i3 REx, 2018 Tesla P3D
It wouldn’t be a bad idea to code HSOC and increase fuel tank. Running the REx daily shouldn’t hurt anything long term. In my 2015 REx it gets used 3-4 times a month.
      09-08-2020, 03:19 PM   #3
Obioban
Emperor
Obioban's Avatar
1647
Drives: M3, M3, M5, M5
2008 BMW M5  [0.00]
2017 BMW i3  [0.00]
2005 BMW M3 Coupe  [0.00]
2001 BMW M5  [0.00]
Shouldn't be any issue using the REx daily for 5 months. I'd do an oil change now, before you start, and another at the end.
It's going to be an annoying 5 months-- you're going to need gas pretty much every day.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport
      09-08-2020, 05:28 PM   #4
WidowMaker03TX
Drives: 2016 i3 REx
Very true. I've owned the car for 13 months and I've only put in four gallons of gas.
      09-09-2020, 11:04 AM   #5
BL 5
The good thing about programming HSOC is you’ll make it home with a decent SOC. I try not to keep my EV’s at a low SOC for an extended period. It’s too bad you can’t even use the wall charger at work. Suppose it’s only for a few months.
      09-09-2020, 07:28 PM   #6
WidowMaker03TX
Drives: 2016 i3 REx
Thanks BL5 and Obioban. I downloaded the Bimmercode app and ordered a Veepeak OBD adapter. I should be coding this week.
      09-10-2020, 10:38 AM   #7
JohnWasser
JohnWasser's Avatar
Drives: BMW i3
Maybe your place of work has an outdoor power outlet you can plug your Level 1 charger into. On a 110v outlet you probably won't get a full charge in 8 hours but it would reduce the need to run the REx. Tell them it's temporary and a pollution-reduction thing.
      09-11-2020, 08:10 PM   #8
WidowMaker03TX
Drives: 2016 i3 REx
Just finished coding REx hold, fuel capacity increase, and set ECO Pro as default with Bimmercode app. In the process, I found that I had left the 110V charging setting to max (bonehead move on my part). I changed the 110V charging setting to low and i3 is accepting a charge in my garage. It's super slow but adds options.
Thanks to all.
      09-12-2020, 02:05 AM   #9
jmg
jmg's Avatar
22117
Drives: G87 M2
Shouldn't be a problem. I used to have to use my REx everyday on my old '15. Fillled it up every few days.
2025 G87 ///M2 LCI - KWHAS, Millway Motorsport Uniball Camber Plates, SPL Adjustable Tie Rods, Unit17 OEM++ Rear Spoiler, Turner Motorsports Front Splitter
Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3
      09-14-2020, 04:21 PM   #10
Myi3reXhandy
Drives: i3 Rex 2015
Originally Posted by WidowMaker03TX View Post
Hi Guys,
I drive about 90 miles each way about 5 days a week I coded to use the real gage on the tank plus I wanted the car to do other things personalized to my like, I do gas once every day charge at night and once on the way back, so do it I will say works for me, I did pay a lot I believe but I didn't know any better back then I took it to a place and a guy did it can't complain
i3 HANDY MOVIL
      09-18-2020, 01:41 PM   #11
wifes first bimmer
Drives: 330i, i3, '82 R65LS
which Veepeak adapter did you buy? There are a few options on Amazon.
I have one similar to that (ELM327, but it does not connect to my i3).
MODS: Turbo Transformer boost controller, ECO-SPORT auto selector (home brew), Electronic boost gauge vent mounted, RPM based LED Carbon paddles
WISHLIST: BM3, HPFP, Turbo + IC + water ... new car eventually
AndyW730.50
      09-18-2020, 06:39 PM   #12
WidowMaker03TX
Drives: 2016 i3 REx
I got the Veepeak OBD Check BLE+ off Amazon.
AndyW730.50
      09-18-2020, 09:20 PM   #13
JohnWasser
JohnWasser's Avatar
Drives: BMW i3
Does your apartment have an electric clothes dryer or an electric oven?
      11-20-2020, 07:47 PM   #14
JohnWasser
JohnWasser's Avatar
Drives: BMW i3
Have you tried Medium? It would be a bit faster than "Low".
      01-01-2021, 03:25 PM   #15
AndyW
Supreme Galactic Commander (one galaxy over...)
AndyW's Avatar
Drives: '08 E93, '12 E82, '13 E93 M3
Thx for this...although I got one and am returning it...didn't work with my phone or my wifes (both Android). Blue light never came on. Would indicated paired and connected, and then immediately disconnect. Neither Carly or Protool could see the adapter. Going to have to figure out another option, I guess.
Best,
Andy
'12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune
      01-02-2021, 11:55 AM   #16
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
Map HSOC to one of the preset buttons so you can easily turn on the REX.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World
